Volvo s70 swap
Old 02-01-2021, 02:40 PM
S70swap's Avatar
Default Volvo s70 swap
Greetings, I recently thought of getting a 1994 volvo 850 glt (b5234T), the car is very beat up but the engine is supposedly in good condition.. I would like to put this engine in a 1998 s70 I have with a blown engine (also the 2.3; b5234T3). What work has to be done for the car to run fine??
Old 02-01-2021, 05:17 PM
you can look at the "volvo modular engine" wiki page to see if there's some extra details on the differences but I'd think a long block from an 850T will work in a 98 S70 T5. I believe the two differences are the 850 uses the 4.3 Motronic and the 98 S70 uses the 4.4. The 850T also used a 15G turbo and the S70 may have a 16T so as long as you use all bolt ons from the S70 (manifolds/turbos etc) it should work. Also note the 850 GLT was an NA engine not the 5234T found on the T5s.
CroVolvo99
07-29-2020 09:55 PM
V_T5
04-11-2015 01:27 PM
danvolvos70
11-28-2010 03:49 PM
Aryding
11-16-2010 09:16 PM
lcb
06-03-2008 05:54 PM
Quick Reply: Volvo s70 swap
