Turn Signal problems
Hello all,
I drive a 1999 Volvo S70, 2.4L. My left flasher does not work but makes a rapid clicking noise. All bulbs work when I use the hazard lights. My right flashers are completely fine. I know that (at least one set of) the relays are located behind the flasher switch on the front panel under the radio. I've gotten a new hazard button assembly with new relays and such (for $57.30), but that did not fix the problem. Any fuses that seem to be related to the flashers also do not look blown. This leads me to think that there is a problem in the wiring. Are there any other fuses or relays that would control the left turn signal that I don't know about? Any other ideas on what would cause the problem? thanks, djacks |
What about the stalk switch?
| All times are GMT -5. The time now is 08:25 AM. |
