vacuum line on s70
where can i find i the vaccum line for a 98 volvo s70 n/a?
i was trying to seafoam the car, but i could not find where the vacuum line from the brake boost was. anyone know? thanks |
Under the black cover ove the throttle body is a vacuum tree that you can connect a line to use for the seafoam.
which line do i use from vacuum tree and does anyone have a diagram of it so i can see which line to use?
And is it better to seafoam the car through the brake boost? thanks, cm123 |
There should be an empty port on the vacuum tree that you can connect a hose to and go.
