volvo s70 wont start
My timing belt tensioner went out, so i replaced it and re timed my car and it still won't start.. ran a compression test wet and dry and it came back normal... i don't have any bent valves... so idk what the problem could be. help?
How do you know you don't have bent valves? Is the car cranking? How did you time the car? Are you getting fuel pressure? Are you getting spark? Lots of unanswered questions.
yes it could be easily fixed if you state exactly whats happening? does the car shut off? does it need a jump? if it rund then cuts off could be the mass air slow sensor.
