-   Volvo S70 (https://volvoforums.com/forum/volvo-s70-33/)
-   -   What Engine do I have? (https://volvoforums.com/forum/volvo-s70-33/what-engine-do-i-have-52219/)
geraldfjs Apr 3, 2011 09:40 AM
I am using my Daughters 1999 Volvo S70. Where can I find what engine I have and whether it is a turbo. I got the numbers off the engine compartment plate but could not figure it out. Thanks.
rspi Apr 3, 2011 06:37 PM
There are several ways to tell if the car is turbo.
  1. Look at the motor. If there is a fat tube that goes over the right side of the motor to the back side (near the fire wall), it is a turbo model. (The big black tube going between the arrows).
    http://atthetipwebs.com/technologyin...0/pict2624.jpg
  2. Look at the sticker on the front of the motor (passenger side of the motor on the S70's), the timing belt cover. If it has a T at the end of it, it is a turbo. (The one below is NOT turbo "B6304 S").
    http://atthetipwebs.com/technologyin...0/PICT1211.JPG
  3. Look on the back of the car, if it has a T in the badge of it, it is likely turbo (very true of all Volvo's built after 1996).
    https://volvoforums.com/forum/member...-wheel-831.jpg
  4. Look at the VIN. The 6th and 7th number in the VIN disclose the engine that is in the car. When you get those 2 numbers, match them up with the VIN decoder on Volvo's website to see the motor specs (that was in the car when it was built).
    Volvo Cars | Community | Your Volvo
  5. Drive the car around and get it warmed up. Pull up next to a kid with a sporty car. Stick your toung out to them then smash the gas down real hard. If the car lunges forward and leaves the kid behing, you have a turbo. If the kid blows by you and leaves you behind, you DON'T have a turbo. :D
Hope you can figure it out.
shadowfist Apr 4, 2011 02:14 AM
hmm... I think I need to test mine again... using method number 5 of course...
OBETSKI Dec 2, 2011 08:02 AM
Hi guys. How would you know if you have 850 or t5? Me and my friend comparing our vin on the vin he has 58 cos he has an R and I have 850. But he said regular 850 should say 55 but mine said 57 on the vin number. Thanks in advance.
