'01 S-80 Timing belt moving off pulleys
Help! I replaced belt, tensioner, and water pump 1K miles ago and the timing belt suddenly has moved 3/4 inch off center pushing serpentine off. I shut down as belt is hanging on by 1/4 inch. WHY? Repair?
Double check to make sure the water pump bolts are tight & torqued. They probrobly are or you would have a leak. Post a few pics please. Can't imagine the water pump shaft bent or coming out?
This can only be a few things. I will assume it's sudden and was aligned well when the job was done.
A damaged or loose pulley or pulley bearing and sometimes an internal cord on a belt can let go. It happens, manufacture a million of something and you can get a bad one. Sometimes a washer can be left off behind a pulley or a spacer missed. I've done it.
