-   Volvo S80 (https://volvoforums.com/forum/volvo-s80-18/)
-   -   '01 S-80 Timing belt moving off pulleys (https://volvoforums.com/forum/volvo-s80-18/01-s-80-timing-belt-moving-off-pulleys-53796/)
patarack May 12, 2011 11:05 AM
Help! I replaced belt, tensioner, and water pump 1K miles ago and the timing belt suddenly has moved 3/4 inch off center pushing serpentine off. I shut down as belt is hanging on by 1/4 inch. WHY? Repair?
bw77 May 12, 2011 12:23 PM
Is the crankshaft balancer pulley tight?
patarack May 12, 2011 04:59 PM
I believe so. The water pump gear seems too far "out" to allow belt to seat against its inner most (closest to the block) and slanted gear face though.
rspi May 12, 2011 08:43 PM
Double check to make sure the water pump bolts are tight & torqued. They probrobly are or you would have a leak. Post a few pics please. Can't imagine the water pump shaft bent or coming out?
gdog May 12, 2011 11:00 PM
Where did you get the parts from? Sounds like a quality issue..
Typhoon May 13, 2011 01:07 AM
This can only be a few things. I will assume it's sudden and was aligned well when the job was done.
A damaged or loose pulley or pulley bearing and sometimes an internal cord on a belt can let go. It happens, manufacture a million of something and you can get a bad one. Sometimes a washer can be left off behind a pulley or a spacer missed. I've done it.
ed7 May 13, 2011 07:25 AM
You didn't mention the idler.
Ed
