02 S80 need some help
Hello all! I am new to the volvo forums and I am working on a volvo with some problems. First off the car is a 2002 Volvo S80 2.9 non-turbo. After recently replacing the engine due to extreme overheating resulting in head damage and loss of compression on 2 cylinders. The problem is after engine replacment the car started first try ran for 4-5 seconds and ran SMOOTH and died. After checking a few things timing,spark,etc. I found out that when the car dies it is due to loss of injection pulse. Help is appreciated. later JS
Any codes stored?
Originally Posted by tech
(Post 164287)
Any codes stored?
Maybe cam sensor is bad.
(Post 164478)
OK it sounds like the immoblizer is kicking in and stopping it from running.
(Post 164655)
Yes it will.But what they will do it first replace the antenna ring(Light around ignition switch) then a key and if none of that worked they would replace the immoblizer and the keys.
(Post 164841)
You can replace it your self without any programming.
(Post 165288)
