1999 80T6 Struts
I need to replace front struts; the front left is leaking fluid. Any recommendations for type and where to buy?
Thanks |
RE: 1999 80T6 Struts
Follow up to last post. The lower ball joint rubber boot is torn. With 130,000 miles should I just rebuild the whole front end if I am going in here? Also the viscous coupler is leaking, pretty good, Comments please.
If you can afford it replace both lower control arms if the bushings are bad.The struts,Don't forget the spring seats to,
Sway bar links, Balljoints. Not sure about the viscous coupler. |
Anyone offer suggestion on type of strut? Koni, KYB, Blis..
From what I have heard and seen the Bilsteen are the best.
yeah i have blisteen and they are great
Tranny fluid from viscous coupler. I just need to replace the mechanical seal on the drive shaft.
Struts, Have looked into in, why are KYB soo cheap? Are they any good or just stay with the proven Bilsteins? Thanks |
KYB is usually a rougher ride from what I hear good for Solid lowered cars.
My last struts were KYB, they felt a little too stiff IMHO.
