1999 S80 Catalytic Converter Need Help
I need to replace catalytic converter and O2 sensors
former owner drove with out working O2 sensor I know to buy it from a dealer its a fortune any suggestion wich aftermarket cat. will work properly and let me pass emission? can I put 2 pipes in to one cat? witch O2 sensor should I buy? are those will work? http://www.amazon.com/Bosch-17036-Oxygen-S...e&carId=003 http://www.amazon.com/Bosch-16198-Oxygen-S...bxgy_auto_img_b |
I just replaced my cat 1999 s80 2.9L about a year ago. No problems yet. I purchased a Davico Brand from Mac Auto Parts. This is the exact one I purchased (see first link below) it was exact fit OEM. You will need to get bolts and gaskets for the CAT. I just went to local Volvo dealer for those. On the O2 sensors Go with Bosch dont mess around with those off brand O2's. I got mine at fcpgroton (second link below). Only needed the front as I was throwing code P0050.
Also, I do a lot of my own work on my S80 (168K now) but I would not attempt to install the CAT yourself. The CAT is attached to the exhaust (Y pipe area) with SS revits and must be torched off. I just took my parts into Merlin Muffler talked to the guy there and they had no problem putting in the cat and O2's for the labor. Install ran $120 well worth it to me. All my Parts $379 (CAT), $200 (O2)+ bolts/gaskets. So for $700 - $800 I was happy. No codes and passed emmisions. Hope this helps. http://cgi.ebay.com/ebaymotors/1999-...mZ220293148177 http://auto-parts.fcpgroton.com/sear...x?query=17036+ |
