1999 S80 No Throttle Response
Hello
I am experiencing a very annoying problem with my 1999 6 cylinder non turbo S80, most of the time the throttle has no response whenever i press on the accelerator and other times it works just fine but with slow throttle response i put it on vida dice diagnostic cable and this is what i found: https://imageshack.com/i/expYUdPkp https://imageshack.com/i/iprABUHip i have had the following done with no use: changed thee alternator changed the throttle changed the tps on the throttle with contactless one changed the accelerator pedal the car seems to work for couple of days whenever i disconnected the battery for five mins but then the problem comes back again and also I noticed that the accelerator has no effect (no throttle response) when pressed at the same time when pressing the brake pedal , not sure if thats normal |
Originally Posted by mohmdomar
(Post 395851)
Hello
