1999 s80 trouble please help
I have a 99 s80 when I depress the gas pedal it will only run to about 1800 rpm any help would be greatly appreciated.
Do you have a cel light?
I do not understand
Could be a couple of things. Biggest culprits are usually the ETM which is discussed at length on this forum and the other can be a faulty ABS module which really makes the computer do funny things. Try disconnecting your battery for a few minutes ( make sure you have radio code) and reattach. Sometimes this will TEMPORARILY fix the issue if it is a faulty ABS module.
Originally Posted by glassbiker
(Post 320215)
| All times are GMT -5. The time now is 09:42 AM. |
