-   Volvo S80 (https://volvoforums.com/forum/volvo-s80-18/)
-   -   2000 S 80 transmission starting to slip should I change fluid? (https://volvoforums.com/forum/volvo-s80-18/2000-s-80-transmission-starting-slip-should-i-change-fluid-82744/)
mojobaby27 02-28-2015 10:09 AM
2000 S 8o 2.9 auto transmission. Starting to slip has 160,000 miles. Should I change fluid? If so what type and how much? Some people recommend flushing some people just drain the pan and do three of four quarts a time. Thanks
Was thinking Mobil ATF 3309 Transmission Fluid - 4 Quart kit .
difflock54 03-03-2015 08:41 PM
'Drain and fill' is the safest and probably the easiest start point in solving the issue.
Many posts exist on forums that advise not to do a flush at all.
What is the color of the ATF on the dipstick and is the fluid level correct?
difflock54 03-03-2015 09:18 PM
http://www.matthewsvolvosite.com/vol...missions-guide
Do you have a 4 speed transmission? AW50-42LE.
JWS 3309 is not suitable for some 4 speeds but is correct for 5 speeds.
See the link above and also check your manual for recommended ATF type.
i.e. Dex III ?
mojobaby27 03-09-2015 09:40 AM
The fluid is reddish /brownish
paper Towel looks reddish brownish, fluid level is A little over recommended hot level, probably A half a quart over.
Transmission type is four speed. FWD. AW5.
I FOUND ATF TYPE TLS ON THE FCP SITE , BY IDEMITSU SAYS IT IS A DIRECT OEM FOR TYPE Volvo gearbox oil 1161540, which is the Volvo part number recommended. seems to be a reasonable price.
