2000 s80
Hi. I am new to this.. I just bought a 2000 S80. I found out the Vehicle Speed Sensor was bad so I had it replaced. Three days later it is doing the same thing. What would cause the problem to happen again? It was running fine. Any suggestions would help. Thank you. :confused:
Hi
I think a little more information may help. Like what exactly happens, when does it happen. Is there a check engine light on? any fault codes? Sensors can be tricky to diagnose. |
Originally Posted by mk2sprite
(Post 384724)
Hi
I think a little more information may help. Like what exactly happens, when does it happen. Is there a check engine light on? any fault codes? Sensors can be tricky to diagnose. Anyways, any more info would be appreciated to help isolate the problem. |
Thank you for your reply. There are no codes that come up. If I start the car it is ok but once I step on the gas it will sputter, make popping sounds, and sounds like a slight backfire. If I try to drive it, it acts like it will die if I am almost stopped and it won't go more than 20 mph. It was doing this before when it did read the code that the vehicle transmission speed sensor was showing. I replaced that part and it ran fine for a few days. Now it is doing the same thing but shows no codes.
The car has multiple lights on like "brake failure" and service engine. I am trying to get it back in shape. I didn't know of these problems when I got it, but I didn't buy it for a lot and the body is in good shape. The car sat for a couple years. The person I bought it from put seafoam in the tank. I replaced the fuel filter and the vehicle transmission speed sensor. I had a code reader plugged into it before I replaced that sensor and it showed the code to replace it. After the sensor was replaced, the car ran fine for 3 days then started to do the exact same thing. I had a code reader plugged into it again and it shows nothing. I have no idea where to begin now. :-(
