cabdoctor |
05-12-2014 11:42 PM |
2000 s80 not starting
My 2000 s80 is doing the typical failed antenna ring symptoms. I was able to get it to crank by shorting to ground the starter relay pin #85 while turning the key and bypassing the immobilizer(of course it didn't start because the injectors wouldn't fire). I pulled the antenna ring and swapped it with the one in my xc90 and the xc fired up just fine with what I expected to be the faulty ring. I put the antenna ring of the xc in the s80 and nothing. The radio, all the lights and accessories work. I tried shifting it into all gears thinking it was the PNP switch and that did nothing. Not sure what it could be.
