2000 s80 climate control lights
Old Nov 22, 2007 | 03:52 PM
Billc's Avatar
Default 2000 s80 climate control lights
Hi, all....new used s80 in wonderful shape, but several lights have gone out in the climate control panel.......can anyone tell me the type of lights to be used and any replacement hints?
Thanks very much in advance.
Bill
Old Nov 25, 2007 | 01:26 AM
mncx's Avatar
Default RE: 2000 s80 climate control lights
It's pretty much u need to go to dealer to get it unless after market company sells them (dealer around $12 each) and recommend u change them all in the climate control module. To take it apart. tear the pen holder off from below climate control. remove 2 torx 25 screws. Jam a Flat screw driver or a thick piece of plastic wedge on top of the center of the climate control unit between the radio. On the side use a hook type pick to Yank out the Climate control module from the top corner of the climate control panel (NOTE: when using the hook type pick hook it up to a secure spot on the climate control module or it can damage the panel itself) hope it helps
Old Nov 25, 2007 | 09:22 AM
Billc's Avatar
Thanks for the info....I'll call the dealer to find out how many bulbs are involved....I've got to replace the HU 801 with a unit with a working cd player, so sounds like both jobs should be accomplished at the same time.
Thanks again.
Bill
mdshumaker
Dec 30, 2014 01:44 PM
centrex11
Sep 8, 2011 07:34 PM
nokinevoli
Sep 11, 2009 12:39 AM
thullz
Dec 14, 2007 06:01 PM
jfikentscher
May 31, 2006 09:58 PM
