2000 S80 ECU pinout
Hi
Have 2000 S80 with 2.8L T6. 133K Having problem with VVT solenoid setting P0013 and P1332 codes. Cleaned VVT solenoid and directly soldered wires to solenoid (cut off connector just in case the connector was the problem) . Still setting codes. Does anyone have a pinout of the ECU for this vehicle? It is not in VADIS. I would like to check continuity of the VVT solenoid wire to the ECU socket before I replace the VVT solenoid. I know the contact number the wire goes to on the ECU from VADIS but I am not sure how the ECU contacts are numbered. Thank you Dennis |
