2001 S80 CC fan problem
When starting the car the fan will come on for an instant but then stop. Will not come on again in any setting, 1-2-3-4, heat, A/C, etc. Just won't blow.
I searched through the 25 pages of this forum and only found refrences to fans working at low speed, etc, but not anything about fan not working at all... like I said it comes on when you turn the key, but once the car is running - nothing. Help! Thanks in advance |
RE: 2001 S80 CC fan problem
Most likely the motor is bad.
It turns on for a Second then the Control module sees it is pulling to Many Amps then the computer shuts it off. |
