2001 S80 T6 - ANTENNA
Anyone know where the antenna is located on the outside? Believe it is in the rear window. I am installing XM Radio. Can I just feed off of that antenna (it comes with a window attachment) or is that bad because it looks like it is integrated into the defrost.
Thanks. |
RE: 2001 S80 T6
There is no outside antenna.
It is in either the back window or the L/R small window. |
RE: 2001 S80 T6
Thanks....if it is in the back window, is it separate from the defrost? or integrated?
RE: 2001 S80 T6
I believe intergrated.
But there is also an antenna booster mounted by the small rear most window. You would have to remove the c-pillar panel to see it though. |
RE: 2001 S80 T6
Thanks, Tech....installed!
RE: 2001 S80 T6
Glad you got it figured out.
