2001 S80 T6 keyless entry problem
Old Dec 13, 2009 | 12:48 AM
trooperone's Avatar
Talking 2001 S80 T6 keyless entry problem
The keyless entry fobs on our 2001 S80 T6 have stopped locking or unlocking the doors suddenly. I changed the batteries in the key fobs, but they still only will unlock the trunk, and activate the interior lights when unlocking, as well as turn the interior lights off when locking. The panic button also still works fine. The only problem is that they will not lock or unlock the doors.
What now??????
Thanks!!
Old Dec 13, 2009 | 01:02 AM
fs's Avatar
fs
I have read on this forum.....lock and unlock the doors with the key three or four times to correct this type of problem. hope this helps
Old Dec 13, 2009 | 01:05 AM
trooperone's Avatar
OK thanks!!! I will try that tomorrow, and if it works I will post it so it may help someone else with the same problem!
Old Dec 13, 2009 | 01:09 AM
fs's Avatar
fs
Yeah, dont leave everyone hanging.....its nice to know if it worked for you, good luck....send check to...........lol....naw, for realz..hope it works
Old Dec 13, 2009 | 01:25 AM
trooperone's Avatar
Haha-good one!! I definitely will post if it does or does not fix it! Thanks again for the tip!!
Old Dec 13, 2009 | 08:39 AM
viommap09's Avatar
Banned
Default 2001 S80 T6 keyless entry problem
Im new on the forum and i just purchase a 98 lx coupe it has the factory keyless entry. But when i hit the button on the remote the doors dont lock. But when i hit the button to unlock the lights come on and I hear the doors unlocking themselves but they are already unlocked. I was just wondering is there something i can check. Also when i tried to lock the car doors with the button on the door I Pulled the door handle and pressed the button and the driverside door didnt lock. But if i manually push the lock on the doornot the button it locks the passengerside. What should i check first.
Old Dec 13, 2009 | 02:55 PM
trooperone's Avatar
OK.....tried the "lock and unlock with the key" method......did NOT correct this particular car's problem. Hmmmmm..............HELP!! Any more ideas to check? Thanks for the input!!!
Old Jan 6, 2018 | 08:17 AM
Bradley Dunagan's Avatar
Default Also my problem
I had this same problem. Turned out for me the two top buttons had broke loose from the circuit board in the remote. Now I have to get a new remote hence my first of many reasons for joining this forum. State by taking your fob apart as if changing the battery. Don’t be surprised if your buttons are broke. My first step is to check a local PC repair place and see if the owner can solder these back on. If not on to another step. Good luck!
What now??????
Thanks!!
ablesdd
Feb 7, 2012 07:58 AM
FujativeOCR
Oct 5, 2009 04:33 PM
kch2000
Mar 19, 2009 08:22 PM
csigrist
Dec 13, 2008 11:48 PM
rickg
May 8, 2007 10:10 AM
