2001 S80 T6 Siren Module Location?
Does anyone know where the siren module is located on the 2001 S80 T6? Are the batteries replaceable? I'm showing the "Alarm System Service Required" message and want to check out the module. Thanks.
RE: 2001 S80 T6 Siren Module Location?
It doesn't have any batteries.
It is located in the R/F fender. You would have to remove the inner fender liner to get to it. |
ORIGINAL: tech It doesn't have any batteries. It is located in the R/F fender. You would have to remove the inner fender liner to get to it. |
Sory to say but it needs to be replaced. We replace alot of them.
Is that a plug-and-play replacement I can do myself or do I need a Volvo dealer toload software? Thanks.
No software but it should be recalibrated by Dealer it Indipendant shop. You can install it them have them calibrate.
OK. Thanks very much!
Your welcome.
You wouldn't happen to know what the AC freon pressures are supposed to be, would you?
Not right off hand I will have to look them up.
