2001 Volvo S80 T6 - P1175 & P1185 Error Codes
Help! The following error codes have come up on my 2001 Volvo S80 T6: P1175 and P1185, which means "System too rich", Inake Blocked, EVAP Canister Purge Valve, Fuel Pressure High, EGR System, Injectors...
I just had the following replaced: Engine Torque Mount Control Arms Ball Joint Timing Belt Kit Mass Air Flow Sensor Water Pump Idler Pulley O2 Sensor Any ideas on what could be the issue? I just put a boatload of money into this car and am hoping that I don't have to put a lot more. Thanks! |
| All times are GMT -5. The time now is 03:32 AM. |
