2002 S80 2.9 timing belt changeout
I am going to change the timing belt, tensioner, and pulley on our 2002 S80. Can you refer me to a "step by step" procedure download for this, or possibly walk me thru it? Also, should I anticipate this being an "all day" job? Your help is most appreciated!! Thanks!
Its not all that bad at all.
Make sure you find all the timing marks also check this site out for General instructions. http://www.babcox.com/editorial/ic/ic60326.htm |
Thanks for the info, and the site! Would you say this is probably going to take a "average person" all day to do?
It should take you a couple if hours.
Says the page is not found..
Looking to do mine and was going to use this as a guide.
Originally Posted by tech
(Post 154866)
Check your water pump while your in there, its part of the loop and would hate to see you have to pull it all apart again. A cam lock tool is also a good idea if you have never done a timing belt. Good luck
