-   Volvo S80 (https://volvoforums.com/forum/volvo-s80-18/)
-   -   2002 S80 steering stops (https://volvoforums.com/forum/volvo-s80-18/2002-s80-steering-stops-29498/)
trooperone Apr 14, 2009 01:10 PM
Having an issue with (particularly on the driver's side) the inside of the tire rubbing on the fender well on a sharp low-speed turn. Someone suggested changing the steering stops. Is this a major job, or does it need to be done at a shop specializing in front end repairs? Any advice is appreciated! Thanks!
tech Apr 14, 2009 08:48 PM
There is only 2 screws holding it onto the control arm.
Make sure the one that is there isn't broke/missing.
If it is there there is a thicker one you can upgrade to.
trooperone Apr 14, 2009 09:46 PM
Thanks a bunch!!! I will check. If the one that is there (or supposed to be) DOES happen to be broken, or missing, where would I find a thicker one? Is that going to be a dealer only type part?
tech Apr 14, 2009 09:53 PM
I believe IPD sells the 3 different ones.
