2003 electrial poblems
hello all, I recently purchased a 2003 s80for my daughter. after a week of driving it his started happening. While driving the dim momentarily shut down and when it came back on the abs/brake failure mesage was displayed. After stopping the car and shutting it off, it would only restart for a second and shut down. A local shop that was nearby reset everything and sent us on our way. a week later a similar thing happened but this time it was anti skid warning. I have had to reset it now 4 times and cant find the fault. I have a list of error codes now bcm-0100, bcm- 0115 bc-0148, bcm-0150, bcm-e000, bcm-e003, cem-6a04,cem-e000, cem-1a5f,cem-1a61, cem-1a62, pdm-0025,sas-0049, sas-e000, sas-e003, tcm-e003.
I have heard alot about the dim problems but would it make the car not start after the failure? Does anyone know of a way to test if it is the dim, cem or any other module? And so far it seems to happen shortly after start up. |
Wont start BCM 0100 & CEM E000
Hello all, I know this as an old post but was the problem ever found?
I have a 2003 V70 that will not start - just cranks and cranks without firing. This is the third time this has happend, when the car does decide to start it will run perfectly for hundreds of miles. It has always appeared after parking over night. I suspect a bad connection somewhere, and ideas anyone? I have BCM 0100 & CEM E000 codes together with a few mirror and alarm codes that have been there for ages. Many thanks |
