2004 S80 Running lights always on
![Exclamation](https://volvoforums.com/forum/images/icons/icon4.gif)
My battery is being drained from my running light in the BACK always being on no matter the state of the car. I need to know what problem so I can fix it myself. I sorta have a feeling its the relay but my owners manual does not tell me anything about relays sadly. Also, my ABS waring light is on but I know what is causing that and don't think they could be related but I really do not know. What do you guys think it could be? I am so so so thankful for anyone who takes the time to help me, seriously. This is my first car in over 10 years and need it fixed before the 9th of Aug so I can start work again. Thank you!!!!
The first step for an ABS light would be a scan with a compatible scan tool. Those codes might point you in the right direction for a solution.
![](https://cimg1.ibsrv.net/gimg/volvoforums.com-vbulletin/1289x862/04s80_park_lt_5a7be7f8987e001c8a131f2cb8c7306670df4303.jpg)
Ive had a similar power drain issue in my 2004 Volvo S80. I checked the voltage of the battery and turned out it wasn’t holding a charge so it might be worth the check. I know the light switch can be a pain since there doesn’t really seem to be an off option. I hope its a simple fix ill look more into it and provide anything I can find. Good luck.
