99 S80 2.9
I'm trying to put an Alpine sound system in my S80. The factory radiomounting bracket isn't fitting with the dash kit that I was sent. It goes half way on and doesn't go on any farther. Also I tried to take off the speaker grilles with a screw driver and got a small crack in it. This leads me to believe that I have to take the door panel off. Is this true and if so, how do I take it off?
RE: 99 S80 2.9
The door panel has clips around the bottom of it.
The handle where you grab to close has one screw under the cover and it should slide off. |
RE: 99 S80 2.9
Thanks, I'll try it when I get a chance.
