'99 S80 Rim / Tire Combo
I am looking to put a new set of aftermarket wheels on my S80. My questions are: Will 20" wheels fit? I Believe 19" is the largest I can go but not positive? Also does anyone know the bolt pattern and offset for this vehicle? Thanks in advance for your time and efforts.
- Cameron |
RE: '99 S80 Rim / Tire Combo
20's will most likely rub. The bolt pattern is 5 x 108. The offset is different for different wheels. Most likely it is in the neighborhood of 41mm - 43mm however.
5X108mm is the bolt pattern.
And again 20's will probably rub a lot. 19's will rub at full lock for sure. Are you looking for Chrome rims because that is mostly what your going to find in 19" and 20" rims. Personally the biggest I would go is 18" rims and tires. 35-42 offset. Those are what the rims are showing on TireRack for a 1999 s80. Again you need to check out these two threads. They will help you a lot when looking for parts. https://volvoforums.com/m_65537/tm.htm https://volvoforums.com/m_38606/tm.htm Personally I would get these rims. They are from TireRack. DiscountTireDirect has nothing good for the s80. O.Z. 35th Anniversary (18") http://www.tirerack.com/images/wheel...nivy_ci3_l.jpg Borbet Type LS (18") http://www.tirerack.com/images/wheel...e_ls_ci3_l.jpg O.Z. Superleggra III (18" and 19") http://www.tirerack.com/images/wheel...lipg_ci3_l.jpg O.Z. Superturismo GT (18" and 19") http://www.tirerack.com/images/wheel...r_gt_ci3_l.jpg O.Z. Ultraleggra (18") http://www.tirerack.com/images/wheel...ra_s_ci3_l.jpg Evolve also sells really nice rims. EVOLVE S80 E7 (18" and 19") http://www.evolvecars.com/site/conte...6ca6c0ae9d.jpg EVOLVE S80 M7 (18" and 19") http://www.evolvecars.com/site/conte...c03d9ca794.jpg |
Why not try to locate some S60R 18's?
I have seen them on a S80 and it looks SWEET. That car also had the black area on each door painted the body color which made it look even better. |
ORIGINAL: tech Why not try to locate some S60R 18's? I have seen them on a S80 and it looks SWEET. That car also had the black area on each door painted the body color which made it look even better. |
But you really don't see that combo on the S80's though.
Thanks everyone! I'm not sure if I will go chrome or not. I like the first rim pic you posted up there (OZ 35th Anniversary), that is a nice looking wheel. I saw on eBay there was a place that you could exchange your stock wheels in for another set of stock rims in chrome? Not sure if I trust places like that though? Thanks again.
ORIGINAL: jks2 20's will most likely rub. The bolt pattern is 5 x 108. The offset is different for different wheels. Most likely it is in the neighborhood of 41mm - 43mm however. |
Well if you move the lift kit from the truck to the Volvo then of course you can put the 24's on it.:D
ORIGINAL: jks2 Well if you move the lift kit from the truck to the Volvo then of course you can put the 24's on it.:D |
Hey it can be done, anything is possible.
I saw an S80 at a meet with at least 19's if not 20's on airbags. Not my style rim because they were Chrome but it was a cool setup. |
I'm liking the looks of these:
http://www.tirerack.com/images/wheel...k_z5_ci3_l.jpg What do you all think? Follow this link to see them on the S80 http://www.tirerack.com/wheels/Wheel...amp;sort=Brand |
Personally I don't like them. It is because I don't like chrome rims. Now chrome rims can look good, but I think they only truly look good on old muscle cars. I know I said I don't like chrome rims but I do think the can look good on old muscle cars just not on anything else.
ORIGINAL: S70driver Personally I don't like them. It is because I don't like chrome rims. Now chrome rims can look good, but I think they only truly look good on old muscle cars. I know I said I don't like chrome rims but I do think the can look good on old muscle cars just not on anything else. |
I don't think so.
ORIGINAL: S70driver I don't think so. http://www.cardomain.com/id/CapoCam |
Hate to burst the bubble again but no. I don't like those personally. 20" is to big and they just aren't classical chrome muscle car rims.
Sorry. |
ORIGINAL: S70driver Hate to burst the bubble again but no. I don't like those personally. 20" is to big and they just aren't classical chrome muscle car rims. Sorry. |
