Access to the stc, trunk lock buttons.
Can anyone tell me how you remove the panel to access the buttons for the STC and Trunk Lock?
My trunk lock switch is not working and needs to be replaced. It is in the lock mode and will not shut off following the directions in the owners manual. |
first i would disconnect the battery for some time, let things reset, then i would play with the remote and that buttong and try to get it to lock / unlock...your suggestion would be my last choice,
but if you want to get at that button, you gota remove the arm rest, cup holder, hand brake cover, center panel around the shifter and then you will see the screws for the a/c and stereo assembly where that button sits, its pretty easy actually |
Thanks,
I was going to just bypass the switch, it's a feature I don't really need anyways, but I'll try the battery thing first. Brian |
