air intake question
Ok same 2000 s80, it looks like it is missing some of the air tubes. There is a nipple/fitting on the main air box with nothing on it and there is a box on the pass. side with a nipple/fitting with no hose....looks like it should go to the intake tube that is maybe 6 inches or so away that goes down below the front air dam. If some has a good pic of this system I can figure out what is missing. This is not my car so I do not have it here, working on it for someone else.
Thank you, Paul |
Turbo or non? I have a non turbo 2.9 and there are two male nipples on the air filter box. Both with hoses that connect to them. Not sure what you are refering to on the passenger side. Can you post some pictures?
If it is a 2.8 turbo maybe this will help
1 Attachment(s)
There is a fitting about 1 inch in diameter coming out the front of the air filter box which has a cap on it sealing it shut.
