ball joint HELP needed
I need help with replacing a ball joint on a S80. I am in the middle of the job and can not get the new ball joint reattached to the control arm. I got the everythiong talken apart and the new ball joint bolted into the hub.
When I try to swing the hub over the control arm - I can't get it lined up. What am I doing wrong? Is there something I need to do differently? Any help would be appreciated. |
RE: ball joint HELP needed
Good luck the Balljoint is actually pressed into the Hub.
There is a special tool that slides over the balljoint then to hit it in with a Hammer. You install the Balljoint in the the Hub the into the control arm. |
Thanks, but I was able to get the new ball joint into the hub. What I can't get is the hub attached to the control arm. I doesn't want to swing back. Do I need to disconnect the strut or is there some other step that I am missing. Thanks
I always use a really big prybar.
If you want you can remove it from the Strut and install. Then reattach to the strut. |
Got the Strut loose, but it doesnt want to move back in place. Could the axel or cv joint have slipped out? If it did - how do you get it back....
Thanks |
Possible the Inner Joint did. It should slide back in with a little bit of force.
