-   Volvo S80 (https://volvoforums.com/forum/volvo-s80-18/)
-   -   Beelding brake oil VS Power Flush (https://volvoforums.com/forum/volvo-s80-18/beelding-brake-oil-vs-power-flush-80757/)
Sherry007 10-24-2014 10:02 AM
I finally decided not to bleed brake oil from brake caliper, kind a careful and messy job for me...bcz have to do by my self.
What if I power flush the brake oil using machine or power bleeder. Hope no harm by using. Kindly advise.
ES6T 10-24-2014 10:18 AM
No harm at all. Just goes quicker. We use them all the time at the dealer.
Sherry007 10-25-2014 03:06 PM
Since I did not find power flush machine around me, I finally did it my self by bleed oil from caliper. The procedure gone smooth. But I suspect two issue but not sure they are serious enough.
1. While taking oil out from caliper I did press and depress the brake few times to get the oil out...otherwise it was not coming (In between I did try to put the handbrake down and put the gear in N so that I might see good flow of oil.
2. Brake is working perfect while drive and no warning sign on dash, but the problem I see that my brake lights still ON while driving, so when I checked I saw my brake pad has a play now or may be lose.
Rest All fine. Kindly advise.
