Bluetooth problems
I recently acquired and installed a Bluetooth handsfree kit for my 99 S80 2.9. Everything works perfectly except the microphone. Also there are some..um...problems... O:-)
1) Microphone has absolutely no sound going through. 2) I removed the side door seal panel that covers the Side Curtain Airbags. In doing so, I stripped a small plastic bolt that hold it on. This need to be replaced ASAP. 3) Under-dash on the passenger side will not go back in and I cannot line up the vertical clips. 4) Side note, my sunroof started to rattle. I recall there being a post about it a while back but I forgot the fix. Any suggestions? |
RE: Bluetooth problems
2 and 3 anyway you can post pics?
4. make sure the cross bar isn't loose causing the rattle. If they are not loose then try to tighten the screws for the glass. |
