both driver's side turn signals not working
Neither of my driver's side turn signals are working. Passenger side works fine. There is a bulb failure message.
The amber light in the front comes on, but the other circuit in the front bulb won't come on. The rear amber bulb will not come on. Won't come on by turn signal or by flasher. I've replaced both bulbs. Please help. |
So I'm pretty sure it's not the bulbs or the sockets. I can open up the fuse panel in the engine compartment and bridge across the wires from the passenger side turn signal wire to the drivers side turn signal wire. When I do this, all the turn signals work.
Problem seems to be there is no current being sent from the fuse panel to the drivers side turn signal wire. Any ideas? |
UPDATE
Well, the problem seems to have fixed itself (for the moment). I guess I'll cancel my appointment with the dealer, but still appreciate any suggestions!!! |
Probably the hazard switch.
