BRAKES re Torque specs for caliper bolts?
I have a 2005 s80 and need to replace the rear brake pads. Do you know what the torque specs are for:
Caliper mounting bolts for -read caliper Caliper mounting bracket bolts for -rear mounting bracket Thanks! |
Ever get an answer? I need them for front/rear as well...
-john |
I've got access to get this info but it will take me until tomorrow... I'm doing the 2008's rears tomorrow night so will double check 2005... hang tight.
Originally Posted by 75ohm
(Post 354589)
Also, I asked this in another thread, but since your doing the 2008 as well, is there a trick to getting an impact hammer or breaker bar enough room to loosen the caliper bolts? There doesn't seem anyway to get the power tool in there and I'm only getting about 3 degrees of rotation with the breaker bar. Thanks in advance for any help! |
Originally Posted by tenui
(Post 354593)
Originally Posted by ES6T
(Post 354598)
You could have just removed the 13mm bolts for the caliper by now and been done with it. Its gotta come off to do the pads anyway.
Are you talking about the pad retainer bolts that hold the retaimer bracket to the spindle or the caliper bolts that hold the caliper to the bracket?
For the 2008... can't confirm for 2005, apologies:
FOR THE REAR: mount rear brake caliper, 110 Nm rotor to hub, 35 Nm two listings: slide rail rear brake caliper, 28 Nm slide rail rear brake caliper, 35 Nm FOR THE FRONT: Slide rail front brake caliper, 28 Nm |
(Post 354598)
2008 was 2x15MM, box wrench and a rubber mallet to move it along... for fun, I tried the 1/2" impact with a wobbler, worked fine... can you post a pic?
I could even sneak a 1/2" 15MM socket in there on a 1/2" driver... |
