Cabin fiter replacement
Hi, I have a 2008 S80, T6 that I am doing the maintenance on. I cannot find the lcation of the cabin filter. I looked at some other posts but mine is not in the same lcation. Any help would be appreciated.
Hello there sparky,
Ok, It's in the same location, kinda, you take off the same panel under the glovebox, then you want to take the one next to it on the center console, find a place to pull and pull good! Next, fold the carpet a little in the front left corner, usually the little fuse cover pops off, if this happens, your doing good. Next, up in the center where the foam was from the carpet, there is three little black clips, just pull on those a little and it should be in there. It squeezes in there somehow. Let me know how you manage. |
That was it, it takes a bit of jockying but its done, thanks
from a 2001, but should get you close
http://www.youtube.com/watch?v=xGEINOvEIkM |
Thanks! I just did it on my XC70
