Missfire on Cyl #6 at WOT only
Old 03-11-2010, 05:46 PM
andrei3333's Avatar
Default Missfire on Cyl #6 at WOT only
so this happens at really hard acceleration when the revs go to the max at different speeds
the code sets as P0306 missfire on cylinder #6, i reset the code, i can replicate these conditions at will, but at normal driving ( when not going nuts on her ) this never happens
all the maintenance is done, new plugs and all, 4 of 6 coils have been replaced EXCEPT #5, and #6
could this be a coil slowly going bad or a bad injector ?
i usually drive normally and try to conserve gas and not beat on her, but when i really need to get out of a jam and floor it this happens, its kinda annoying, she runs fine and quiet with perfectly steady rpms at idle...gas mileage is normal for this car and very consistent for the year and a half that i owned here
any thoughts ?
Old 03-11-2010, 09:11 PM
I would say the coil is going out.
Old 03-12-2010, 07:39 AM
NoLifeTilBoost's Avatar
Swap coils #2 and #6, if the misfire code moves to cyl #2, then you have your answer
Old 03-12-2010, 08:12 AM
andrei3333's Avatar
yeah im kidna too lazy to take the turbo hoses off though lol, ill try on the weekend, i may just drive until the coil fails completely
Old 03-12-2010, 09:17 AM
Consider this though, if it starts to misfire regularly under normal use, aside from the nasty-*** vibrations you can possibly wipe out a cat and O2 sensors from the unburnt fuel.....Now thats going to be some work.
Old 03-12-2010, 07:30 PM
+1 to that!
Old 03-12-2010, 10:14 PM
andrei3333's Avatar
ok fine i might as well just buy a coil online its like 50 canadian plus shipping for 11 dollars
thanks for the help guys...
lj320
04-20-2010 02:09 PM
kyvahe
06-25-2009 08:04 PM
Cobra_03
01-31-2009 10:04 AM
hispeed
04-09-2008 05:31 PM
Quick Reply: Missfire on Cyl #6 at WOT only
