Check Engine
Emission System Service Required is the message appearing on my S80 any ideas whats wrong and how much this one will cost?
RE: Check Engine
As tech would say, Under that message it could be anything, Most common thing is its the o2 sensors:
When my emissions system service came on(came on 2 different occasions)- 1.)mass air flow sensor 2.)throttle body you need to pull the codes. |
RE: Check Engine
could be an assortment of things. Usually it's the 02 sensor, but could also be a bad ect sensor, bad secondary 02, bad tps (etm), bad map reading, etc.
RE: Check Engine
Best thing to do is pull the codes first and see what they say.
