Check engine,abs trac light on????
1999 S80 2.9.Ok i know the check engine is for the the o2 sensor that is on the way. jjust ordered them, its only one code bank 2 something.. But recently the abs and the trac light are on i dont wanna take the car to a dealer just to check that. i think i've seen on past posts that i cant find that when both lights are on at the same time its because the abs control module is bad???? Just want a opinion from you guys before i take it to an expert to check it?????
Most likely the module is bad. You can remove it and have it rebuilt for about $100.00
Ohhh thanks... and where is the abs module located near the abs pump?????and do i need a mechanic to put that or i can do do it myself, and after i put it new will it reset the lights by itself or it will need and scanner for that thanks in advanced
Check this link.
This will tell you how to do it. |
Where's the link???
Sorry Brain Fart!!!
http://home.earthlink.net/~vicrocha/...vo_V70_ABS.htm |
E5 is your friend.
Thanks !tech! I bought a rebuilded one its working and no funny lights on my dash thanks again for making me save a couple of hundreds lol
Glad it is all well now.
