check engine codes
Check engine light popped back on, I figured i was sick of paying VOLVO for their service charge so i went out and bought a fairly decent obdii scanner. Hooked it up and pulled the following...
P0354 Ignition Coil primary/secondary circuit P1152 which i cant find but I believe is an o2 sensor code? Tech or anyone please offer help on both codes and expenses to fix? or whatnot thanks! |
RE: check engine codes
Yes 1152 is an O2 sensor code Rear o2 sensor.
Not sure about the coil code I would have to try to find the crossrefrence to be able to tell you. Thats the only bad thing using the OBDII scanners and the P codes. I have to have a chart to be able to crossrefrence to Volvo codes. |
how urgently would the o2 need to be replaced... I know they can eat up the cat but im thinking that with 120K on a 99 maybe the cat is shot anyways?
You can go a little but I wouldn't go to long.
