How do you separate air inlet hose from MAF?
So what's the trick for removing the plastic air inlet hose from the MAF (Mass Air Flow) sensor? I loosen the hose clamp and the hose spins around the MAF but I can't pull it apart! I'm afraid to pry it with a screwdriver for fear of cracking either the hose or the MAF.
Thanks...
Thanks...
