check engine results
so ive had the check engine light on for a while. i havent taken it to the dealer to get fixed bc they charge 250 just to look at it. so i found a shop that works on swedish cars and got it checked there. here are the results 1. ecm-1600 one of the o2 sensors in front 2. ecm-1600 boost pressure signal 3. ecm-170f atmospheric pressure sensor/ boost/ pressure sensor fault and to fix all this is about 500 bucks or a 1.5 of my paycheck. anyone know the parts i need and if ill be able to fix myself? or am i better off paying the 500 bucks cause i got a lil mechanical knowledge so what do you guys think?
You can replace the sensors yourself easy enough. The front O2 is a pain to get to and involves dropping the exahust, but not complicated. The real question is are the sensors actually the problem.
How has the car been behaving? |
