Climate Control Problem Please Help!
I recently installed an AUX input converter on my S80. To do it, I removed the climate control unit from underneath the stereo. When I put it back together, the climate control unit doesn't work, and the "Service Airbag" warning is up. Any ideas?
RE: Climate Control Problem Please Help!
Try having the codes cleared.
Can I do it myself with an OBD or do I need a dealer?
Only the Dealer or an Indipendant shop that can read the codes.
Someone on here had the same problem and there was a simple fix but I couldn't find it. |
OK thanks. Hopefully I can get it figured out. I'll try to get to a dealer this weekend
Have you tried disconnecting the battery for a few?
If not disconnect it. Then connect the + and - cables together for 5 minutes. That will discharge all the computers.(That is only touch the cables together. Not jump across the battery) Then try to connect and see if it works. |
Nope - haven't tried that yet. Will do right now, let you know...
It doesn't seem to have worked... I left it off and the terminals connected for 15 minutes and it didn't clear anything. The SRS alert is still up and the HVAC controls are still non-op. Sigh... This really sucks!
Yes it does Sorry that didn't work.
Have the Dealer clear the codes. I wish I could find that post. It was an easy fix. The Dealer wanted to replace the module on that car and it wasn't the problem but I forget what was. |
I really really hope you can find the post/info, cause that's the only next step I can think of. I really don't want to spend the $$.
I will try to keep searching.
So TECH, did you ever find out what that easy fix was for the problems with the climate control and SRS warning? I have been reading about this on here in dozens of threads and nothing?
I have the same exact problem right now with my 2002 S60. What was the solution to the problem?
| All times are GMT -5. The time now is 04:59 AM. |
