Code Help
I don't have the volvo codes but i do have OBDII codes if any of you could help me out as to specifics that would be great.
P0442: EVAP emissions control system leak (small) P0134: O2 sensor CKT No Activity (bank 1 sensor 1) P1172: Manufacturer control Fuel Air metering P0301: Cylinder 1 misfire detected P0135: O2 sensor heater circut malfunction (bank 1 sensor 1) If you can help me out with what specifically these codes are for, other than the small explanation given that would be great, thanks. |
RE: Code Help
That's a lot of codes to cross reference. Are they all current and not corrected? You won't get much more information on the codes except how to fault trace them. It might be easiest for you to get a copy of VADIS and look them up yourself. If you email me I can give you step by step instructions on getting a copy if you don't know how. davecrobinson@Hotmail.com
RE: Code Help
Looks like a bad coil or spark plug in cylinder 1 and a bad front O2 sensor on the passenger side.
Also look like a minor leak in the evap system. |
RE: Code Help
thanks tech,
i figured that it would possibly be either a bad plug, maybe wire. and i was going to replace that 02 sensor. i just wasn't sure if it could possibly be a fuel injector. I have VADIS on my computer i am just not sure how to cross reference the codes. but i am going out now to buy all new plugs for my car, depending on the money i have available possisbly an 02 sensor. then come home and do that and clean the ETM. Thanks for the info |
RE: Code Help
There is a cross over table in there I have it printed out but forget how to get to it.
Maybe someone that remembers will post if. I am going to try to figure it out as well so I can post it. |
RE: Code Help
It's under:
Information manager - Engine - Diagnostic information - General diagnostics and tests - 20 general - conversion tables standardized diagnostic trouble codes(DTCs)/Volvo diagnostic trouble codes(DTCs) |
RE: Code Help
Hope this is easy enough to figure out. Here she is in all her glory. Complete cross-reference.
P0010ECM-6400Intake camshaft reset valveSignal too low or signal missing P0011ECM-640ACamshaft control, intakeFaulty signal P0013ECM-6410Exhaust camshaft reset valveSignal too low or signal missing P0014ECM-641ACamshaft control, exhaustFaulty signal P0016ECM-643ACamshaft position, exhaustSignal too high P0016ECM-643ACamshaft position, exhaustSignal too low P0017ECM-644ACamshaft position, exhaustSignal too low P0017ECM-644ACamshaft position, exhaustSignal too high P0030ECM-2810Front heated oxygen sensor (HO2S), preheatingSignal missing. Intermittent fault P0030ECM-2810Front heated oxygen sensor (HO2S), preheatingSignal missing. Permanent fault P0031ECM-2810Front heated oxygen sensor (HO2S), preheatingSignal too low. Intermittent fault P0031ECM-2810Front heated oxygen sensor (HO2S), preheatingSignal too low. Permanent fault P0032ECM-2810Front heated oxygen sensor (HO2S), preheatingSignal too high. Intermittent fault P0032ECM-2810Front heated oxygen sensor (HO2S), preheatingSignal too high. Permanent fault P0036ECM-2A20Heated oxygen sensor (HO2S) bank 1, preheatingSignal missing P0037ECM-2A20Heated oxygen sensor (HO2S) bank 1, preheatingSignal too low P0038ECM-2A20Heated oxygen sensor (HO2S) bank 1, preheatingSignal too high 0050ECM-2910Front heated oxygen sensor (HO2S) preheating, bank 2Signal missing P0051ECM-2910Front heated oxygen sensor (HO2S) preheating, bank 2Signal too low P0052ECM-2910Front heated oxygen sensor (HO2S) preheating, bank 2Signal too high P0056ECM-2B20Heated oxygen sensor (HO2S) bank 2, preheatingSignal missing P0057ECM-2B20Heated oxygen sensor (HO2S) bank 2, preheatingSignal too low P0058ECM-2B20Heated oxygen sensor (HO2S) bank 2, preheatingSignal too high P0068ECM-903CThrottle position (TP) sensorFaulty signal P0071ECM-1100Outer temperature sensorFaulty signal P0072ECM-1100Outer temperature sensorSignal too low P0073ECM-1100Outer temperature sensorSignal too high P0101ECM-130AIntake air leakageFaulty signal P0102ECM-1300Mass air flow (MAF) sensorFlow too low. Intermittent fault P0102ECM-1300Mass air flow (MAF) sensorFlow too low. Permanent fault P0103ECM-1300Mass air flow (MAF) sensorFlow too high. Intermittent fault P0103ECM-1300Mass air flow (MAF) sensorFlow too high. Permanent fault P0105ECM-1000Control moduleFaulty signal P0107ECM-1000Control moduleSignal too high / signal too low. Intermittent fault P0107ECM-1000Control moduleSignal too high / signal too low. Permanent fault P0108ECM-1000Control moduleSignal too high / signal too low. Intermittent fault P0108ECM-1000Control moduleSignal too high / signal too low. Permanent fault P0112ECM-1200Intake air temperature (IAT) sensor inletSignal too high. Intermittent fault P0112ECM-1200Intake air temperature (IAT) sensor inletSignal too high. Permanent fault P0113ECM-1200Intake air temperature (IAT) sensor inletSignal too low. Intermittent fault P0113ECM-1200Intake air temperature (IAT) sensor inletSignal too low. Permanent fault P0121ECM-9150Throttle unit, potentiometer 1Faulty signal P0122ECM-9150Throttle unit, potentiometer 1Signal too low P0123ECM-9150Throttle unit, potentiometer 1Signal too high P0128ECM-201AThermostatFaulty signal P0130ECM-280AFront heated oxygen sensor (HO2S), faulty signalSignal missing. Intermittent fault P0130ECM-280AFront heated oxygen sensor (HO2S), faulty signalSignal missing. Permanent fault P0132ECM-280AFront heated oxygen sensor (HO2S), faulty signalSignal too high. Intermittent fault P0132ECM-280AFront heated oxygen sensor (HO2S), faulty signalSignal too high. Permanent fault P0133ECM-280AFront heated oxygen sensor (HO2S), faulty signalSignal too low. Intermittent fault P0133ECM-280AFront heated oxygen sensor (HO2S), faulty signalSignal too low. Permanent fault P0134ECM-280AFront heated oxygen sensor (HO2S)Faulty signal. Intermittent fault P0134ECM-280AFront heated oxygen sensor (HO2S)Faulty signal. Permanent fault P0135ECM-2810Front heated oxygen sensor (HO2S), preheatingFaulty signal. Intermittent fault P0135ECM-2810Front heated oxygen sensor (HO2S), preheatingFaulty signal. Permanent fault P0136ECM-2A0ARear heated oxygen sensor (HO2S)Signal missing. Intermittent fault P0136ECM-2A0ARear heated oxygen sensor (HO2S)Signal missing. Permanent fault P0137ECM-2A0ARear heated oxygen sensor (HO2S)Signal too low. Intermittent fault P0137ECM-2A0ARear heated oxygen sensor (HO2S)Signal too low. Permanent fault P0138ECM-2A0ARear heated oxygen sensor (HO2S)Signal too high. Intermittent fault P0138ECM-2A0ARear heated oxygen sensor (HO2S)Signal too high. Permanent fault P0140ECM-2A1ARear heated oxygen sensor (HO2S) agingSignal too low P0140ECM-2A1ARear heated oxygen sensor (HO2S) agingSignal too high P0140ECM-2A1ARear heated oxygen sensor (HO2S) agingSignal missing P0141ECM-2A2ARear heated oxygen sensor (HO2S), preheatingFaulty signal P0150ECM-290AFront heated oxygen sensor (HO2S), bank 2Signal missing. Intermittent fault P0150ECM-290AFront heated oxygen sensor (HO2S), bank 2Signal missing. Permanent fault P0152ECM-290AFront heated oxygen sensor (HO2S), bank 2Signal too high. Intermittent fault P0152ECM-290AFront heated oxygen sensor (HO2S), bank 2Signal too high. Permanent fault P0153ECM-290AFront heated oxygen sensor (HO2S), bank 2Signal too low. Intermittent fault P0153ECM-290AFront heated oxygen sensor (HO2S), bank 2Signal too low. Permanent fault P0154ECM-290AFront heated oxygen sensor (HO2S), bank 2Faulty signal. Intermittent fault P0154ECM-290AFront heated oxygen sensor (HO2S), bank 2Faulty signal. Permanent fault P0155ECM-2910Front heated oxygen sensor (HO2S) preheating, bank 2Faulty signal. Intermittent fault P0155ECM-2910Front heated oxygen sensor (HO2S) preheating, bank 2Faulty signal. Permanent fault P0156ECM-2B0ARear heated oxygen sensor (HO2S), bank 2Signal missing. Intermittent fault P0156ECM-2B0ARear heated oxygen sensor (HO2S), bank 2Signal missing. Permanent fault P0157ECM-2B0ARear heated oxygen sensor (HO2S), bank 2 P0157ECM-2B0ARear heated oxygen sensor (HO2S), bank 2 P0158ECM-2B0ARear heated oxygen sensor (HO2S), bank 2Signal too high. Intermittent fault P0158ECM-2B0ARear heated oxygen sensor (HO2S), bank 2Signal too high. Permanent fault P0160ECM-2B1ARear heated oxygen sensor (HO2S) ageing, bank 2Signal too low P0160ECM-2B1ARear heated oxygen sensor (HO2S) ageing, bank 2Signal too high P0160ECM-2B1ARear heated oxygen sensor (HO2S) ageing, bank 2Signal missing P0161ECM-2B2ARear heated oxygen sensor (HO2S) preheating, bank 2Faulty signal P0171ECM-261ALong-term fuel trimUpper limit P0172ECM-261ALong-term fuel trimLower limit P0174ECM-271ALong-term fuel trim, bank 2Upper limit P0175ECM-271ALong-term fuel trim, bank 2Lower limit P0201ECM-2310Injector 1Signal missing. Intermittent fault P0201ECM-2310Injector 1Signal missing. Permanent fault P0202ECM-2320Injector 2Signal missing. Intermittent fault P0202ECM-2320Injector 2Signal missing. Permanent fault P0203ECM-2330Injector 3Signal missing. Intermittent fault P0203ECM-2330Injector 3Signal missing. Permanent fault P0204ECM-2340Injector 4Signal missing. Intermittent fault P0204ECM-2340Injector 4Signal missing. Permanent fault P0205ECM-2350Injector 5Signal missing. Intermittent fault P0205ECM-2350Injector 5Signal missing. Permanent fault P0206ECM-2360Injector 6Signal missing. Intermittent fault P0206ECM-2360Injector 6Signal missing. Permanent fault P0221ECM-9160Throttle unit, potentiometer 2Faulty signal P0222ECM-9160Throttle unit, potentiometer 2Signal too low P0223ECM-9160Throttle unit, potentiometer 2Signal too high P0230ECM-2400Fuel pump (FP) relaySignal missing. Intermittent fault P0230ECM-2400Fuel pump (FP) relaySignal missing. Permanent fault P0231ECM-2400Fuel pump (FP) relaySignal too low. Intermittent fault P0231ECM-2400Fuel pump (FP) relaySignal too low. Permanent fault P0232ECM-2400Fuel pump (FP) relaySignal too high. Intermittent fault P0232ECM-2400Fuel pump (FP) relaySignal too high. Permanent fault P0234ECM-6805Turbocharger (TC) control valve, boost pressure faultPressure too high P0235ECM-1600Boost pressure sensorFaulty signal P0236ECM-170FAtmospheric pressure sensor / boost pressure sensor range checkFaulty signal. Intermittent fault P0236ECM-170FAtmospheric pressure sensor / boost pressure sensor range checkFaulty signal. Permanent fault P0237ECM-1600Boost pressure sensorSignal too low. Intermittent fault P0237ECM-1600Boost pressure sensorSignal too low. Permanent fault P0238ECM-1600Boost pressure sensorSignal too high. Intermittent fault P0238ECM-1600Boost pressure sensorSignal too high. Permanent fault P0243ECM-6800Turbocharger (TC) control valveSignal missing. Intermittent fault P0243ECM-6800Turbocharger (TC) control valveSignal missing. Permanent fault P0245ECM-6800Turbocharger (TC) control valveSignal too low. Intermittent fault P0245ECM-6800Turbocharger (TC) control valveSignal too low. Permanent fault P0246ECM-6800Turbocharger (TC) control valveSignal too high. Intermittent fault P0246ECM-6800Turbocharger (TC) control valveSignal too high. Permanent fault P0261ECM-2310Injector 1Signal too low. Intermittent fault P0261ECM-2310Injector 1Signal too low. Permanent fault P0262ECM-2310Injector 1Signal too high. Intermittent fault P0262ECM-2310Injector 1Signal too high. Permanent fault P0264ECM-2320Injector 2Signal too low. Intermittent fault P0264ECM-2320Injector 2Signal too low. Permanent fault P0265ECM-2320Injector 2Signal too high. Intermittent fault P0265ECM-2320Injector 2Signal too high. Permanent fault P0267ECM-2330Injector 3Signal too low. Intermittent fault P0267ECM-2330Injector 3Signal too low. Permanent fault P0268ECM-2330Injector 3Signal too high. Intermittent fault P0268ECM-2330Injector 3Signal too high. Permanent fault P0270ECM-2340Injector 4Signal too low. Intermittent fault P0270ECM-2340Injector 4Signal too low. Permanent fault P0271ECM-2340Injector 4Signal too high. Intermittent fault P0271ECM-2340Injector 4Signal too high. Permanent fault P0273ECM-2350Injector 5Signal too low. Intermittent fault P0273ECM-2350Injector 5Signal too low. Permanent fault P0274ECM-2350Injector 5Signal too high. Intermittent fault P0274ECM-2350Injector 5Signal too high. Permanent fault P0276ECM-2360Injector 6Signal too low. Intermittent fault P0276ECM-2360Injector 6Signal too low. Permanent fault P0277ECM-2360Injector 6Signal too high. Intermittent fault P0277ECM-2360Injector 6Signal too high. Permanent fault P0299ECM-6806Turbocharger (TC) control valve, flow faultPressure too low P0300ECM-3503Misfire, at least one cylinderEmissions impact / catalytic converter damage P0301ECM-3513Misfire cylinder 1Emissions impact / catalytic converter damage P0302ECM-3523Misfire cylinder 2Emissions impact / catalytic converter damage P0303ECM-3533Misfire cylinder 3Emissions impact / catalytic converter damage P0304ECM-3543Misfire cylinder 4Emissions impact / catalytic converter damage P0305ECM-3553Misfire cylinder 5Emissions impact / catalytic converter damage P0306ECM-3563Misfire cylinder 6Emissions impact / catalytic converter damage P0324ECM-3400Knock sensor (KS), test pulseSignal too high / signal too low. Intermittent fault P0324ECM-3400Knock sensor (KS), test pulseSignal too high / signal too low. Permanent fault P0324ECM-34E0Knock sensor (KS), offsetSignal too high / signal too low. Intermittent fault P0324ECM-34E0Knock sensor (KS), offsetSignal too high / signal too low. Permanent fault P0324ECM-34F0Knock sensor (KS), test pulseSignal too high / signal too low. Intermittent fault P0324ECM-34F0Knock sensor (KS), test pulseSignal too high / signal too low. Permanent fault P0327ECM-3410Knock sensor (KS), frontSignal too low. Intermittent fault P0327ECM-3410Knock sensor (KS), frontSignal too low. Permanent fault P0328ECM-3410Knock sensor (KS), frontSignal too high. Intermittent fault P0328ECM-3410Knock sensor (KS), frontSignal too high. Permanent fault P0332ECM-3420Knock sensor (KS), rearSignal too low. Intermittent fault P0332ECM-3420Knock sensor (KS), rearSignal too low. Permanent fault P0333ECM-3420Knock sensor (KS), rearSignal too high. Intermittent fault P0333ECM-3420Knock sensor (KS), rearSignal too high. Permanent fault P0335ECM-5200Engine speed (RPM) sensorSignal missing P0336ECM-5200Engine speed (RPM) sensorFaulty signal P0337ECM-5200Engine speed (RPM) sensorSignal too low P0338ECM-5200Engine speed (RPM) sensorSignal too high P0340ECM-3000Camshaft position (CMP) sensor, intakeFaulty signal or signal missing P0342ECM-3000Camshaft position (CMP) sensor, intakeSignal too low. Intermittent fault P0342ECM-3000Camshaft position (CMP) sensor, intakeSignal too low. Permanent fault P0343ECM-3000Camshaft position (CMP) sensor, intakeSignal too low. Intermittent fault P0343ECM-3000Camshaft position (CMP) sensor, intakeSignal too low. Permanent fault P0344ECM-3000Camshaft position (CMP) sensor, intakeFaulty signal or signal missing P0345ECM-3010Camshaft position (CMP) sensor, exhaustFaulty signal or signal missing P0347ECM-3010Camshaft position (CMP) sensor, exhaustSignal too low P0348ECM-3010Camshaft position (CMP) sensor, exhaustSignal too high P0349ECM-3010Camshaft position (CMP) sensor, exhaustFaulty signal or signal missing P0351ECM-3300Ignition coil cylinder 1, signalSignal missing. Intermittent fault P0351ECM-3310Ignition coil cylinder 1, signalSignal missing. Permanent fault P0352ECM-3300Ignition coil cylinder 2, signalSignal missing. Intermittent fault P0352ECM-3310Ignition coil cylinder 2, signalSignal missing. Permanent fault P0353ECM-3320Ignition coil cylinder 3, signalSignal missing. Intermittent fault P0353ECM-3320Ignition coil cylinder 3, signalSignal missing. Permanent fault P0354ECM-3330Ignition coil cylinder 4, signalSignal missing. Intermittent fault P0354ECM-3330Ignition coil cylinder 4, signalSignal missing. Permanent fault P0355ECM-3340Ignition coil cylinder 5, signalSignal missing. Intermittent fault P0355ECM-3340Ignition coil cylinder 5, signalSignal missing. Permanent fault P0356ECM-3350Ignition coil cylinder 6, signalSignal missing. Intermittent fault P0356ECM-3350Ignition coil cylinder 6, signalSignal missing. Permanent fault P0422ECM-4801Three-way catalytic converter (TWC) efficiencyIntermittent fault P0422ECM-4801Three-way catalytic converter (TWC) efficiencyPermanent fault P0432ECM-4901Three-way catalytic converter (TWC) efficiency, bank 2Intermittent fault P0432ECM-4901Three-way catalytic converter (TWC) efficiency, bank 2Permanent fault P0442ECM-400CFuel tank system, leakage P0443ECM-4000Evaporative emission system (EVAP) valveSignal missing. Intermittent fault P0443ECM-4000Evaporative emission system (EVAP) valveSignal missing. Permanent fault P0444ECM-4000Evaporative emission system (EVAP) valveSignal too high. Intermittent fault P0444ECM-4000Evaporative emission system (EVAP) valveSignal too high. Permanent fault P0445ECM-4000Evaporative emission system (EVAP) valveSignal too low. Intermittent fault P0445ECM-4000Evaporative emission system (EVAP) valveSignal too low. Permanent fault P0446ECM-4010Leak diagnostic unit, valveSignal too high P0447ECM-4010Leak diagnostic unit, valveSignal missing P0448ECM-4010Leak diagnostic unit, valveSignal too low P0456ECM-400CFuel tank system, leakage P0457ECM-4338Fuel tank filler cap missing P0460ECM-405CFuel level sensor P0461ECM-4050Fuel level sensorFaulty signal P0462ECM-4050Fuel level sensorSignal too low P0463ECM-4050Fuel level sensorSignal too high P0464ECM-4050Fuel level sensorSignal missing P0480ECM-6110Engine cooling fan (FC) relaySignal missing. Intermittent fault P0480ECM-6110Engine cooling fan (FC) relaySignal missing. Permanent fault P0484ECM-6100Engine cooling fan (FC) control moduleFaulty signal. Intermittent fault P0484ECM-6100Engine cooling fan (FC) control moduleFaulty signal. Permanent fault P0496ECM-4007Evaporative emission system (EVAP)Signal too high P0497ECM-4007Evaporative emission system (EVAP)Signal too low P0500ECM-510FSpeed signal P0502ECM-510FSpeed signal P0504ECM-510FSpeed signal P0506ECM-990AIdle air control (IAC)Faulty signal P0507ECM-990AIdle air control (IAC)Faulty signal P0560ECM-8010Battery voltageFaulty signal P0562ECM-8010Battery voltageSignal too low P0563ECM-8010Battery voltageSignal too high P0564ECM-928CControl module, communication faultFaulty signal P0571ECM-9400Brake pedal sensorSignal missing P0573ECM-9400Brake pedal sensorSignal too high P0579ECM-928CControl module, communication faultFaulty signal P0580ECM-928CControl module, communication faultFaulty signal P0581ECM-928CControl module, communication faultFaulty signal P0604ECM-9050RAM memory faultInternal fault. Intermittent fault P0604ECM-9050RAM memory faultInternal fault. Permanent fault P0605ECM-9060ROM memory faultInternal fault. Intermittent fault P0605ECM-9060ROM memory faultInternal fault. Permanent fault P0606ECM-9070Engine control module (ECM)Internal fault. Intermittent fault P0606ECM-9070Engine control module (ECM)Internal fault. Permanent fault P0607ECM-711AControl module, internal faultSignal too high / signal too low. Intermittent fault P0607ECM-711AControl module, internal faultSignal too high / signal too low. Permanent fault P0630ECM-720AImmobilizer communicationFaulty signal. Intermittent fault P0630ECM-720AImmobilizer communicationFaulty signal. Permanent fault P0634ECM-715DEngine control module (ECM), high temperature P0638ECM-91A7Throttle unitFaulty signal P0642ECM-8410Power supply 5 VoltsSignal too low. Intermittent fault P0642ECM-8410Power supply 5 VoltsSignal too low. Permanent fault P0643ECM-8410Power supply 5 VoltsSignal too high. Intermittent fault P0643ECM-8410Power supply 5 VoltsSignal too high. Permanent fault P0645ECM-6000Air conditioning (A/C) relay, signalSignal missing. Intermittent fault P0645ECM-6000Air conditioning (A/C) relay, signalSignal missing. Permanent fault P0646ECM-6000Air conditioning (A/C) relay, signalSignal too low. Intermittent fault P0646ECM-6000Air conditioning (A/C) relay, signalSignal too low. Permanent fault P0647ECM-6000Air conditioning (A/C) relay, signalSignal too high. Intermittent fault P0647ECM-6000Air conditioning (A/C) relay, signalSignal too high. Permanent fault P0650ECM-6B00Malfunction indicator lamp (MIL), signalSignal missing. Intermittent fault P0650ECM-6B00Malfunction indicator lamp (MIL), signalSignal missing. Permanent fault P0650ECM-6B00Malfunction indicator lamp (MIL), signalSignal too low. Intermittent fault P0650ECM-6B00Malfunction indicator lamp (MIL), signalSignal too low. Permanent fault P0650ECM-6B00Malfunction indicator lamp (MIL), signalSignal too high. Intermittent fault P0650ECM-6B00Malfunction indicator lamp (MIL), signalSignal too high. Permanent fault P0668ECM-7180Temperature sensor control moduleSignal too high / signal too low. Intermittent fault P0669ECM-7180Temperature sensor control moduleSignal too high / signal too low. Permanent fault P0700ECM-530DDiagnostic trouble code (DTC) in another control module P0727ECM-3100Engine speed (RPM) sensorSignal missing. Intermittent fault P0727ECM-3100Engine speed (RPM) sensorSignal missing. Permanent fault P0805ECM-9300Clutch pedal sensorFaulty signal P0807ECM-9300Clutch pedal sensorSignal too low P0808ECM-9300Clutch pedal sensorSignal too high P0863ECM-530BControl module communication P1177ECM-268ALong-term fuel trimUpper limit P1178ECM-268ALong-term fuel trimLower limit P1179ECM-268ALong-term fuel trimFaulty signal P1187ECM-278ALong-term fuel trim, bank 2Upper limit P1188ECM-278ALong-term fuel trim, bank 2Lower limit P1189ECM-278ALong-term fuel trim, bank 2 P1234ECM-6814Turbocharger (TC) control systemSignal too high P1273ECM-9117Throttle unitFaulty signal P1281ECM-917FThrottle unitFaulty signal P1285ECM-913FThrottle unitFaulty signal P1286ECM-913CThrottle unitFaulty signal P1287ECM-913CThrottle unitFaulty signal P1293ECM-914FThrottle unitFaulty signal P1480ECM-6100Engine cooling fan (FC) control moduleFaulty signal. Intermittent fault P1480ECM-6100Engine cooling fan (FC) control moduleFaulty signal. Permanent fault P1481ECM-6110Engine cooling fan (FC) relaySignal too low. Intermittent fault P1481ECM-6110Engine cooling fan (FC) relaySignal too low. Permanent fault P1482ECM-6110Engine cooling fan (FC) relaySignal too high. Intermittent fault P1482ECM-6110Engine cooling fan (FC) relaySignal too high. Permanent fault P1526ECM-980AEngine control module (ECM). Internal faultIntermittent fault P1526ECM-980AEngine control module (ECM). Internal faultPermanent fault P1554ECM-801ASystem relayFaulty signal or signal missing P1555ECM-801ASystem relayFaulty signal or signal missing P1630ECM-E003Control module, internal faultFaulty signal. Intermittent fault P1630ECM-E003Control module, internal faultFaulty signal. Permanent fault P1638ECM-716DEngine control module (ECM), high temperature P1651ECM-981AEngine control module (ECM)Internal fault. Intermittent fault P1651ECM-981AEngine control module (ECM)Internal fault. Permanent fault P1652ECM-982AEngine control module (ECM)Internal fault. Intermittent fault P1652ECM-982AEngine control module (ECM)Internal fault. Permanent fault P1680ECM-720AImmobilizer communicationSignal missing. Intermittent fault P1680ECM-720AImmobilizer communicationSignal missing. Permanent fault P1721ECM-6220Control module cooling fanSignal too high P1722ECM-6220Control module cooling fanSignal too low P1723ECM-6220Control module cooling fanSignal missing P1729ECM-9170Throttle unitFaulty signal P2088ECM-6400Intake camshaft reset valveSignal too low or signal missing P2089ECM-6400Intake camshaft reset valveSignal too low or signal missing P2090ECM-6410Exhaust camshaft reset valveSignal too low or signal missing P2091ECM-6410Exhaust camshaft reset valveSignal too low or signal missing P2096ECM-262ALong-term fuel trimUpper limit P2097ECM-262ALong-term fuel trimLower limit P2098ECM-272ALong-term fuel trim, bank 2Upper limit P2099ECM-272ALong-term fuel trim, bank 2Lower limit P2101ECM-9100Engine control module (ECM)Faulty signal P2108ECM-919AEngine control module (ECM)Faulty signal P2109ECM-918AEngine control module (ECM)Internal fault. Intermittent fault P2109ECM-918AEngine control module (ECM)Internal fault. Permanent fault P2111ECM-91B7Throttle unitFaulty signal P2112ECM-91C7Throttle unitFaulty signal P2121ECM-9540Accelerator pedal (AP), digital signalFaulty signal P2122ECM-9530Accelerator pedal (AP) position sensor, digital signalSignal too low P2123ECM-9530Accelerator pedal (AP) position sensor, digital signalSignal too high P2126ECM-9520Accelerator pedal (AP) position sensor, analogy signalFaulty signal P2127ECM-9520Accelerator pedal (AP) position sensor, analogy signalSignal too low P2128ECM-9520Accelerator pedal (AP) position sensor, analogy signalSignal too high P2131ECM-9400Brake pedal sensorFaulty signal P2177ECM-260ALong-term fuel trimUpper limit P2178ECM-260ALong-term fuel trimLower limit P2179ECM-270ALong-term fuel trim, bank 2Upper limit P2180ECM-270ALong-term fuel trim, bank 2Lower limit P2300ECM-3300Ignition coil cylinder 1, signalSignal too low. Intermittent fault P2300ECM-3300Ignition coil cylinder 1, signalSignal too low. Permanent fault P2301ECM-3300Ignition coil cylinder 1, signalSignal too high. Intermittent fault P2301ECM-3300Ignition coil cylinder 1, signalSignal too high. Permanent fault P2303ECM-3310Ignition coil cylinder 2, signalSignal too low. Intermittent fault P2303ECM-3310Ignition coil cylinder 2, signalSignal too low. Permanent fault P2304ECM-3310Ignition coil cylinder 2, signalSignal too high. Intermittent fault P2304ECM-3310Ignition coil cylinder 2, signalSignal too high. Permanent fault P2306ECM-3320Ignition coil cylinder 3, signalSignal too low. Intermittent fault P2306ECM-3320Ignition coil cylinder 3, signalSignal too low. Permanent fault P2307ECM-3320Ignition coil cylinder 3, signalSignal too high. Intermittent fault P2307ECM-3320Ignition coil cylinder 3, signalSignal too high. Permanent fault P2309ECM-3330Ignition coil cylinder 4, signalSignal too low. Intermittent fault P2309ECM-3330Ignition coil cylinder 4, signalSignal too low. Permanent fault P2310ECM-3330Ignition coil cylinder 4, signalSignal too high. Intermittent fault P2310ECM-3330Ignition coil cylinder 4, signalSignal too high. Permanent fault P2312ECM-3340Ignition coil cylinder 5, signalSignal too low. Intermittent fault P2312ECM-3340Ignition coil cylinder 5, signalSignal too low. Permanent fault P2313ECM-3340Ignition coil cylinder 5, signalSignal too high. Intermittent fault P2313ECM-3340Ignition coil cylinder 5, signalSignal too high. Permanent fault P2315ECM-3350Ignition coil cylinder 6, signalSignal too low. Intermittent fault P2315ECM-3350Ignition coil cylinder 6, signalSignal too low. Permanent fault P2316ECM-3350Ignition coil cylinder 6, signalSignal too high. Intermittent fault P2316ECM-3350Ignition coil cylinder 6, signalSignal too high. Permanent fault P2400ECM-4024Leak diagnostic unit, pumpSignal missing P2401ECM-4024Leak diagnostic unit, pumpSignal too low P2402ECM-4024Leak diagnostic unit, pumpSignal too high P2404ECM-431DLeak diagnostic unitFaulty signal P2405ECM-431DLeak diagnostic unitSignal too low P2406ECM-431DLeak diagnostic unitSignal too high P2407ECM-431DLeak diagnostic unitSignal missing |
RE: Code Help
thank you everyone,
I changed all the plugs, and that solved the misfiring problem. I unplugged the 1st passengers side O2 sensor to find that one of the cables had frayed and split, so i spliced that and now the car is up and running better. Although the Engine light did come back on for the 02 sensor, but i erased it and will see if it comes back again, and will go from there. |
alright since the last update, my car had been running fine, for about a week, then i ran some codes again and it is saying that the O2 sensors have either no activity or low voltage, this is bank 1 sensor 1 and bank 1 sensor 2, could this possibly be a catalytic converter problem, because now my car is quite loud and is idling rough?
Thanks in advance |
I would say bad sensors.
thanks for the insight tech, i just wanted some insight as to what the problem might be because either one is an expensive fix. i will check the O2 sensor for carbon and see if they need to be replaced, if not i will go on from there.
