code P0155 - a Oxygen Sensor - options?
2000 Volvo S80 regular engine, 130k miles. Check engine light illuminates, and a scanner shows the code P0155 - a Oxygen Sensor. Clear the code and light - comes back within a few miles of operation. Car runs fine - no stumbling, stalling, etc.
What are my options? If replacement of the sensor, I was told that there are 4 of them on the car - how do I determine which one and where it physically is located? Does it screw in and have a plug for the wiring, or is there more to changing it? And is there a perticular replacement brand I should use or stay away from? |
RE: code P0155 - a Oxygen Sensor - options?
That code is for the drivers side front sensor.
I would replace with OEM brand sensor.(Bosch) The sensor screws in and had a wiring harness off of it that gets unplugged. |
Thanks for the fast responce!
Please excuse my ignorance about this - but how does one gain access to the sensor? From the top, or below? Anything have to be removed to get to it? Thanks! Vince |
Below.
Sometimes the exhaust has to be dropped some other times you can reach it easy. |
