codes p0722 and p1618 along with dstc light
I'm getting these codes so I'm assuming ABS module but, I have no symptoms that I'm aware of. Could it be anything else?
So, in an attempt to fix my sunroof I inadvertently fixed my problem. I have no idea why or how but, replacing the faulty alarm siren took care of the speed sensor code. I thought the siren was supposed to be link to the sunroof?
So, the codes came back today. I thought it was odd that the siren would have fixed them. I figured it had to be something I bumped while replacing the siren though. I unplugged the wheel speed sensor plugged it back in and what da yah know the codes went away. So I'm going to replace that wheel speed sensor and see what happens.
Hey, i also have a p0722 output speed sensor no signal code coming up, so did you say that unplugging and plugging fixed the speed sensor issue?
Only for a few hundred feet and then they came back again. The big thing I noticed was that after unplugging and plugging back in the sensor the dstc button started working again, showing on or off in the message screen. I don't think this was from the unplugging but, rather just moving the sensor wires around in general.
Crazy
Originally Posted by jdmser
(Post 273954)
