coolant leak?
hi.
i bought my 2000 s80 turbo in august, and it since then i've had to fill my coolant three times. i'm wondering if this is normal for this car or if i should get it checked for a leak. i'm thinking there must be a leak because it is getting to be less time between having to fill it each time. help! |
RE: coolant leak?
Have it checked for a leak.
RE: coolant leak?
im having the same problem i was told a common area are the two heat hoses comming from the inside of the car to the engine i had a leak on the driver side one and also lucky me on the bottom of the tank. you might want to check those out.
