2001 S80 Dies while idling
Old 10-01-2011, 06:50 PM
laguilar's Avatar
Default 2001 S80 Dies while idling
My S80 dies while idling, the fuel filter was replaced. Any suggestions?
Old 10-02-2011, 06:39 AM
poopbunny's Avatar
Get diagnostics to pull codes.
Only speculating here...
- Fuel pump
Old 10-17-2011, 07:54 PM
Lunger's Avatar
I would lean towards a bad crank or cam sensor. Which in turn would throw the iginition timing off by means of the ECU. A code would help pin point this though.
Old 11-07-2011, 08:01 PM
hughrhodes's Avatar
Could be a dirty ETM. Easy fix. Does the idle fluctuate alot before it dies?
Great Youtube video show you easy way to clean.
Fixing Volvo Rough Idle Problems (ETM issues) - YouTube
Old 12-18-2011, 12:11 AM
Lunger's Avatar
yes the ETM could be going out. also a bad fuel pressure regulator could be the cause.
free1959
09-11-2011 02:59 PM
lukaspanic
03-17-2011 12:32 AM
BRDVPRA
10-24-2009 08:30 PM
thekoopa
06-11-2009 07:18 PM
MarkInTexas
05-26-2009 05:28 PM
Quick Reply: 2001 S80 Dies while idling
