Driver Side Heated Seat...
Tech,
ju So my front passenger seat heater works fine, but the driver side heated seat doesn't seem to work... I've checked under the seat and there is a female connection that isn't connected but other than that there aren't any other wires that are not already plugged in...The button has power... and lights up, I jus seem to be missing smthing simple to fix this.. I apologize if this thread has already been dealt with in the past... I didn't check to see.. Thanx dreaded 99' S80 :( |
RE: Driver Side Heated Seat...
It is kind of hard to say without seeing since you said all the wiring is good.
There is a seat module and sometimes it will store codes. Sadly that might be the only way to see whats going on. |
