dtcs service on ip and stuck in third gear
need some one with experience on this matter this is my first Volvo (owned) it is stuck in third gear and wont up shift or down shift...I have replaced the transmission, gear shifter, dtcs module yaw sensors under the seat and center counsel any one with knowledge (other than set it on fire and roll it down hill) would be greatly appreciated
Welcome to the forum :D
New Member is a place to introduce yourself and your car but your cars area is where to ask for help. Post moved to correct area. You should add the cars info like year as I'm sure you'll be asked. It says S80 in your screen name but some people have multiple Volvos so it's not always clear. If you add the info to your signature it helps. |
